it depends on the mast hight, the first 34P had a clearance of 15metres without antennes or windex later they extended the mast with 0.5m, the bridgeclearance of 16.5m will be a gamble
Hi ALan,
everything alright overthere?
In this link link removed by administrator due to article copyright, heightclearance is 14,9 meters.
you will find the heightclearance. It is in German, but you can read every language, so…
succes and have a pleasant holiday.
ciao,Riesmo39634,7903472222
Alan,
the dufour website has a technical specs , specifying the air draft as 15.1 meters.
This is the link: dufour-yachts.com/fileadmin/ … ufour_34.p df
Allowing 1 meter for antenna, you will need very flat water to clear a 16.5m bridge. It would make me very nervous…
best regards,
Lucas
